85 k5 carb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ed1507, Jan 25, 2003.
  1. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    dose any one know if i can replace the stock 4bb quad with a after market one it has the elect power pump can it be disconcted ed /forums/images/graemlins/k5.gif
  2. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    first things first, fill in your user profile and you'll get a lot more responses to your questions..
    the 85 has the quadrajet with electric choke...to make it easy go ahead and get an aftermarket carb with the electric choke, just swap the one wire and the ground over to the new carb and thats done...
    if its street only, try the edelbrock performer w/ electric choke, they're pretty nice for daily drivers...
    the electric choke equipped carbs cost a little more, but it saves you from having to run a manual choke to the cab..
    good luck
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes you can leave electrical for the Q jet disconnected when you put on aftermarket carb, if the Qjet is in good running shape then save it someone could use it im sure
    good luck
  4. ed1507
    Jan 25, 2003
    70
    indiana
    any one know what the power pump dose in the qjet ? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  5. dyeager535
    26,975
    How many electrical plugs are on the carb, excluding the choke one?
  6. ed1507
    Jan 25, 2003
    70
    indiana
    theres a 2 wire plug in on the top of the carb on the right side /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    where at in indiana?? i live in frankfort and might b able to help
    NITRO
  8. dyeager535
    26,975
    Read the '86 preliminary manual last night.
    That's a dual capacity pump. It's purpose is to provide extra fuel for cold engine idle-cruise transition. At 170* the solenoid energizes, eliminating the supply of additional fuel used for the cold temp transition period. If it were me I'd leave it alone, it hurts nothing, disconnected, it would unnecessarily hurt mileage.
