85 k5 HEI ignition
Discussion in 'The Garage' started by bamurf80, Jul 4, 2006.
  1. bamurf80
    bamurf80 Newbie
    Jun 27, 2006
    3
    mo
    I have an 85 k5 that dones not have any spark to the plugs. I have replaced everything in the dist. i am getting power to the coil but no power to the 4 wires in the rear of the dist. Could it be the ECM under the dash on the pass. side that is not giving it power and allowing it to spark?
    Any help would be great
    thanks
    Bamurf80
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Are you sure you replaced EVERYTHING in the distributor? Did you replace the pick-up coil? In order to replace it you must remove the distributor and completely take it apart. If this part fails you won't get any spark to the plugs just the same as when the module goes bad.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    My 85 did the same thing, and I jumpered two of the wires of the 4. The ECM was bad, and not letting the signal back to the dist. If its the same as mine (85C20) all it does is control the spark timing (retard for spark knock) I just jumpered the two wires and set my timing old school.
  4. bamurf80
    bamurf80 Newbie
    Jun 27, 2006
    3
    mo
    Which two wires did you jump? And when you say jumpered what exactly do you mean buy that?
    Sorry for all the dumb questions. I am new to this kinda thing
    Bamurf80
