85 no-tilt-no-cruise column Q's.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stevewix, Feb 23, 2005.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    for reasons i'm going to try not to mention, the end of my '85 column is taken apart. the problem i'm having is getting the ign. cylinder gear teeth lined up, and i can't seem to do it. i'm either 1 tooth in front, behind or way the 'f' off! can anyone shed some light on this subject?
    clarification, the lock cyl will either want to start the truck off of 'lock', or won't be able to travel far enough and hit it's stop with the glow plugs stll running.
    does this truck have an acc mode where you turn the key back? i don't think the lock cylinder is provisioned for it...
  2. dyeager535
    26,975
    I believe all the GM columns used an accessory position.
