85 s10 case swap
Discussion in '1983-2005 S-Series models' started by big4x4ride, Aug 29, 2005.
  1. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    Have an 85 s10 blazer, t4/np207, can i do a direct swap to a 27 spline assenger drop 208?? same adapter and oiutput shaft ??
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    out put shaft is the same but the adapter is not, the np207/np231 have a 5 bolt pattern while the np208/np241 is a 6 bolt pattern.
  3. big4x4ride
    Feb 11, 2004
    216
    Corpus Christi, TX
    well damn what can i do to adapt it any ideas??
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    use the adapter that goes with the 208. The 208 adapter will bolt right up to your trannys rear. The back of the trannny is the same for full size and s-10's
  5. big4x4ride
    Feb 11, 2004
    216
    Corpus Christi, TX
    which adapter though, this is a t4 tranny not offered in full sizes
