86 blazer gears
Discussion in 'The Garage' started by jd70ssclone, Jan 6, 2007.
  1. jd70ssclone
    jd70ssclone 1/2 ton status
    Nov 29, 2006
    125
    baltimore
    i have a 86 blazer with a 305 and a 700r4 overdrive tranny what rear gears do you think my stock ten bolts have?
    thanks guys
    josh
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Probably 3.08's
  3. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    ^what he said, but youd need to pull the cover off and count the number of teeth on the pinion and ring gear and then divide the number of teeth on the ring gear by the number of teeth on the pinion to know for sure
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hmmmmmm.....
    I've seen K5s come stock with 3.08s, 3.42s and 3.73s. In fact, my 84 came from the factory with 3.73s. If yours came with a factory-installed receiver hitch, chances are you have the 3.73s, too.
    If you still have a readable RPO sticker, it shoud tell you what gears you have. Gearing codes start with a G, and if you google "RPO codes", you'll find a ton of sites that can help you decipher your sticker.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Look inside the glovebox for the options sticker. My options sticker listed 3.73 gears & locking differential on my 85.
    Harley
  6. jd70ssclone
    Nov 29, 2006
    125
    baltimore
    yea guys thanks alot for the help i popped the glovebox to find out that i have 373 gears a locking diff and the high output 305 plus a tow pack
    josh
