86 Blazer K5 305 bogs down on acceleration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JW86, Aug 20, 2002.
  1. JW86
    JW86 Registered Member
    Aug 20, 2002
    40
    Bolivar, Texas
    Idles pretty good, but when accelerating bogs down or loses power then comes back and surges. If i run at 2500 rpm in 2nd seems smooth, but accelerate and shift, gets bad. I have been working on the vac system, but not sure if im on the right track. Any help appreciated!
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    When's the last time you changed the fuel filter. It only takes 15 mins and is cheap. Even if it doesn't solve the problem it probably needs it any way.
  3. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    you might check the fuel system. I replaced everything in my timing system to fix a problem similar in my 86. i then replaced fuel lines and pump. little did i know there's a filter in the carb itself right by the inlet that hadn't been replaced. i replaced it and it worked no problem
  4. JW86
    Aug 20, 2002
    40
    Bolivar, Texas
    Thanks, have one on the bench just hadn't got to it yet. I have only owned this one for 2 weeks and ran better before i started to "fix" it. Will get it in this PM and see what happens.
  5. dyeager535
    26,982
    190
    Make sure to use a tubing wrench and 1" open end on the fuel line fitting when repalcing the filter, or you'll end up replacing the steel fuel line.
    Putting the tubing wrench on the fuel line nut, holding the 1" wrench on the large carb inlet/filter "nut", and delivering a sharp blow (however you can manage it) on the tubing wrench will usually break it free without twisting the fuel line. If you can reach it, disconnecting the steel fuel line at the fuel pump end will also help a little in preventing line twist.
  6. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    i had the same prob a while back and it was the fuel pump...
    peace.
    HAYDUKE
  7. JW86
    Aug 20, 2002
    40
    Bolivar, Texas
    Replaced fuel filter (nasty) but did not help. ALso replaced the EGR valve since it was a mess. Will check the Fuel pump today. On test drive, was pretty boggy and missing enough to make it embarassing to drive... maybe an ignition problem?
