86 Burb + 76 GMC LB + 454
Discussion in 'The Garage' started by Trick1, Mar 17, 2007.
  1. Trick1
    Trick1 Newbie
    Mar 17, 2007
    Milwaukee WI
    Hello folks, Great site!!
    I have a 76 GMC seirra 1/2 ton 4X4 pick up with a 6 banger 4 gear in it.
    I picked up a 86 4X4 burb with a rebuilt 4speed auto and a smokey motor with a plow on it.
    And I have this rebuilt 454.[​IMG]
    I want to put the drive train out of the burb in the 76 with the 454.
    I will go with buckets and a floor shift.
    Is this a plug and play deal? I,m sure frame stands will need to be changed.
    The 76 has newer diffs in it had 411s but went with 308s for hiway cruising.
    Also I think the Xfer case is toast with a bad vibration.
    It does have a new front driveshaft in it though
    The burb is rusty but 4wd works nice.
    Will the plow swap to the 76?
    Thanks for any comments.
  2. Trick1
    Trick1 Newbie
    Mar 17, 2007
    Milwaukee WI
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    all of this should be bolt in, the plow should fit as well. I think the only front end differences between p/u and burb are bumper brackets
