'86 Burb Longer driveshafts needed??
Discussion in 'The Garage' started by 86haubs, Jun 2, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    I have an 86 1/2t burb, I am thinking about putting a 6" lift but I do not want to if I have to get longer shafts. I do not want to go with 4" because I want 35's w/o cutting. Please help!
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Depends on the lift kit, some are taller than others. The front will probably need to be lengthened or at least have a spacer put on. Spacer is about $70. Rear should be ok from what I've heard others say.
  3. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    A 4" shackle flip lift, plus a 2" or 3" lift block should allow you to lift the rear of your truck without a longer drive shaft because a shackle flip moves your axle forward. And if you go with 6" srings for the front, and a 1" drive shaft spacer, this should keep you from having to lengthen any drive shafts.
  4. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Thanks for the replies, I thought I needed to know, but I guess not. My wife just went out and bought me a superlift 4"kit. Well I am doing 35's anyways!
