86 CUCV starter problem
Discussion in 'The Garage' started by greggyg, Apr 4, 2006.
  1. greggyg
    greggyg Newbie
    Sep 25, 2005
    Virginia
    I don't really have any idea how to go about fixing this. But when i went to start my blazer the starter stuck and kept running after a had taken the key out, then i went and turned the disconnect switch off, after i turned it back on the starter started spinning again finally after the next time i disconnected it shut off, and i got back in and it started up with no problems. Afterwards i realized that my stereo had blown out and i had to brake lights but all the other lights were fine. Does anyone got any advice. Thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    sounds like your selnoid might have stuck closed
  3. goldwing2000
    goldwing2000 Guest
    That would be my guess. Welded contacts inside the solenoid. If you're still running a 24V system, I have no idea where you would find another one. :dunno:
  4. greggyg
    greggyg Newbie
    Sep 25, 2005
    Virginia
    thanks. thats what im thinking now too. when it happened it blew 3 fuses and the one in my radio. So i guess it is time to convert it from 24V to 12
  5. 5150_BEAST
    5150_BEAST Registered Member
    Oct 9, 2005
    62
    Los Angeles
    86cucv starter problems
    smack it with an m-16....thats what we used to do in the army...those piles were always having some problem or another...but when they run right they will run through a brick wall and mow down the enemy:D
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Try this place http://www.nationsautoelectric.com/ . They list repair parts for most (all?) starters including the 24V CUCV. Save the wear and tear on the butt stock of your M16 :rolleyes:
  7. 5150_BEAST
    Oct 9, 2005
    62
    Los Angeles
    cucv starter problems...
    you liked that one huh diesel dan...the m-16 is more than a killing weapon,and starter smacking tool...you should see how well of a rotisserie it makes:D :haha:
