86 engine swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, May 20, 2001.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I'm looking to put a new engine in my 86 Blazer with a 700-R4 trans. What I'm wondering is if a newer year model 350 will hook up to the tranny. IF so what isthe newest engine I could use. The reason I ask is because I haven't been able to find a after market crate engine with the torque range I want, and I was hoping to get a stock crate engine from a newer model with more Horsepower. Any information would be a great help. Thanks in advance
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    You can bolt up any small block 350 engine you want to that transmission. Look at GM's crate engines, they have a Vortec 330hp that can be gotten with GM Part# 12496968. It's complete from carb to oil pan. Also Includes Chromed Air Cleaner and Plug Wires. All you need is oil and spark plugs. Price $3,095.99 or a long block GM Part# 12486041 Price $2,095.99 These are brand new engines from GM. Either one is a bolt in for you. Try here:
    http://www.paceparts.com/
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You will also need a new flex plate since 86 was the odd ball year. That is no big deal. $60.00 part from GM...Dan
