86 f350 4x4
Discussion in 'The Garage' started by meangreen, Apr 29, 2004.
  1. meangreen
    meangreen Registered Member
    Apr 27, 2004
    6
    I just found a 86 f350 4x4 cheap, anyone know what axles are in them? looking to swap into 91 k5.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    front is a HP D60, rear is a dana 70 or a 10.25 sterling /forums/images/graemlins/waytogo.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    should be noted, Ford front axles have the pumpkin on the driver side, means you need to switch to a ford transfer case too. which I don't believe the F350s will be likely to just bolt in.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you could also swap a 241 in from a 88 and newer truck or 92 and newer sub, blazer, or tahoe. that will be a bolt in to a 700r4
  5. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    better check the spring perch width. I think its quite different from our trucks!
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Spring perch width is an issue with that truck. You need a '78-79 F350 for the prefered axle to bolt into a GM truck.
  7. meangreen
    Apr 27, 2004
    6
    as far as the width couldn't you just weld in the correct spring perch so you could use the chevy springs? I've seen it done on jeeps and scouts all the time, kevin
  8. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    On the 86' F350 you'd have to change out the tube on the drivers side for a longer piece of tubing and shorten the pass side (while keeping the pumpkin on the drivers side). Also moving the perch on the pass side. Then you'd need inner axle shafts from 78'-79' ford d60. After all that it will work /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if you can weld cast... no you still can't. You'd have to mount the spring on top of the pumpkin which would be like a 6" block.
  10. Stomper
    May 11, 2002
    3,767
    Iowa
    not if you left it on the drivers side and used ford t-case
  11. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Check this truck carefully, it's either 80-85 or 80-86 Ford used the TTB D50 in the F350's - not a D60. Basically if you can see a hinge in the middle of the axle skip it.
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The switchover was mid-year '85, so an '86 has the 60 for sure.
