86 Front Clip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz316, Jul 30, 2001.
  1. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    I purchased an 86 Custom Deluxe front clip on saturday. I paid a hundred bucks for it. It came with both fenders the hood the wheel well liners the grill the wiper cowl radiator support and even the AC condenser. Is there any thing else that I may need Ive looked over the upgrade in the tech specs I just wanted to make sure I had everything.
    73 K5, 350, auto w/factory air....How sweet it is.
  2. dyeager535
    26,979
    Friend just did this swap on a '76. The gap between the doors and the fenders was excessive afterwards. Not sure why, no way he could fix it, but I'm thinking after all the twisting the sheetmetal gets, it is anything but "as manufactured" by this time in its life.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Be careful how the radiator goes in. Make SURE it fits. I swapped a 74 rad. to an 83, and I didn't have the right mounts. It popped out the other day and made out with my flex fan.
    So, if you are swapping in your old radiator, triple check thaqt everything fits. I got to looking at it, and the rad. supports really weren't the right width to fit the rad. anyways.
    Good luck.
    Lift It, Lock It, LIVE IT!!!
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You need the hood hinges and seals off of the doner truck. You will need to cut holes in the cowl to mount the hinges. use the doner truck to develop some templates for the cutting. Other than that it is pretty straight forward.
    '85 K5 : Run it til it breaks, then fix it and go again!
