86 gas tank into 78?s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Apr 26, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Will a 86 k5 gas tank bolt into a 78? IF not what is required?
    Dan
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    All 2nd gen gas tanks will fit each other. The exception is the sending unit needed for your application, " ie. return line, vacuum port, and such ".
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    All 2nd gen gas tanks will fit each other. The exception is the sending unit needed for your application, " ie. electric fuel pump, return line, breather port, and such ".
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thanks.
    Dan
