86 k-5 auto to man. hubs/ Do I need a conversion kit?
Discussion in 'The Garage' started by chrisnjj, Nov 8, 2002.
  1. chrisnjj
    chrisnjj Registered Member
    Oct 22, 2002
    7
    Vermont-summer/Costa Rica-winter
    I have the stock 5 torx screw auto hubs and want to install warn manual hubs. Some places say I need a spindle nut conversion kit and some say I dont. Which is it??
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    No conversion kit is needed. All of the auto stuff just pulls out, and the manual stuff goes in. The only thing you've got to watch is to make sure you take out one washer/spacer (directions will tell you which one - doesn't need a tool - it's just a washer), but other than that, it's no harder than turning a few screws and inserting some retaining clips.
  3. chrisnjj
    Oct 22, 2002
    7
    Thanks heavy4x4. That sounds cheaper and eaiser for me.
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I understand your concern. I am thinking about changing my auto to manual on my 90 blazer. When I looked at the Warn web page they state that bYOU need the conversion kit.
    Dan...
  5. heavy4x4
    Aug 28, 2002
    3,270
    Okay guys, here's the deal...I swapped in manual hubs in place of my autos. No problem, no kit was needed. But...I have an NP241 transfer case. I don't know whatkind of t-case you have, but if you have an NP203 (big cast iron hunk o' metal), you may need some sort of "part-time" conversion kit. I'm not positive on this, so someone else speak up please. What I do know is that if you have an NP241, 205, or 208, you won't need any conversion kit to replace your auto hubs with manuals.
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    86 has a 208 so no kit is necessary. i did my swap about two months ago. other than fighting to get the outer hub lock ring off it was an easy swap.
  7. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the confirmation. I just couldn't remember.
    Yeah, when I did it I went out and bought a snap ring pliers. Made things easy - and now I've got one more tool /forums/images/graemlins/smirk.gif
