86 k5 distributor help!!!
Discussion in 'The Garage' started by rodney chambers, Feb 2, 2006.
  1. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    my 86 had electronic spark control which had a ghost. sometimes it ran sometimes not. i removed the esc distributor and installed an original hei out of an 80 k5.. if i set the timing to factory 4 deg the engine pings(predetonation) if i advance it the ping is worse. if i retard til the ping goes away it will hardly pull in OD. WHAT AM I MISSING???:confused:
  2. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    do you have the vac line off the dist and plugged?
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    maybe the magnetic sensors inside the dis??
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I had the same dilema on my 86 305 I put in my 79 C10..I ditched the EST Q-jet and dist,and put a 1976 305 HEI in it with a vacuum advance..did exactly what you described,until I moved the vacuum advance hose to MANIFOLD vacuum,rather than ported..just the opposite of most chevy's,they usually use ported vacuum..no more pinging,it pulls well,even got 2 mpg more !..my timing pointer is missing,so I timed it "by ear",so I cant tell you the exact timing specs..it starts without binding,doesn't ping,and isn't sluggish,so it must be about perfect...someday I'll bolt the pointer I found in my junk drawer on my timing cover,and see where its set at,for the hell of it..
  5. rodney chambers
    Jun 23, 2005
    50
    northeast oklahoma
    that would be the only place i havent put it. i'll give it a try. thanks
