86 k5 ecm?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rodney chambers, Dec 14, 2005.
  1. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    traced wiring from distributor through firewall on k5. manual calls it an ecm. is this the case. having intermittent death while driving . let it set a while and it will start. wondering if this could be the problem. is there a troublshooting procedure for this component?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    There's not much troubleshooting for these, other than a direct replacment to see if a different one works. This is a very weird year for GM, is your engine TBI, computer carbed, or just carbed? My '86 C10 4.3L has a non-computer carb on it. I still have one of these, it's only function is spark knock, and when to open the purge valves on the charcoal canistor.
  3. rodney chambers
    Jun 23, 2005
    50
    northeast oklahoma
    this is a computer carb engine. i have noticed if i let the engine warm up and let the choke kick off the engine runs fine. i am thinking i have a choke problem
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It could be a distributor problem. The module. Easy to get at and the chain parts stores will test them for free.
    Could be choke, The elec. chokes aren't really known for going bad though. Do you have power to the choke?
