86 k5 trans going I think
Discussion in 'The Garage' started by Justin Fleming, Sep 26, 2006.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    The trans is what I beleive to be a 700r4. When truck is cold the trans does not want to shift out of 1st and as it gets warmed up it shifts ok but seem to be lackadasive. The question is........what 700r4 trans is a good replacement? I know that these came in anything from s10s to camaros. will any 700r4 work or what are the options for a direct replacement?
    thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    any 4x4 trans should work for you, as long as it was a 90 degree pattern, you might want to look for the later 88 up trannys they had a lot of parts that were changed to make them a lot better from the early ones
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Locally I found a 91 chevy 4.3 v6 with a 700r4 trans out of a s10 pickup and I can get it all for 100. Based on what you have said above it should be a direct replacement?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes that is a direct replacment, and thats a really good deal, are you getting the engine and tranny?
  5. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    If your going to put a v6 700 behind a v8 dont expect it to last very long, they ahve less clutches and weaker parts in some applications.. just a fyi.. nate
  6. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Hey Nate don't you work at a Tranny Shop?
    As for a replacement I would suggest the following...
    1) local shop, nice if there is ever a problem
    2) somone like www.maddogtransmissions.com he seems to be really cool and I have only heard great things about him
    3) Factory GM replacement through your local dealer
    4) find a 2nd generation 700r4 and have the local shop rebuild it
    That is the list that I have come to like from my searches regarding this very topic as my 700r4 is also on its last leg.
    Mine doesn't like to shift out of first either, just get into the throttle then when it racks up enough rpm's just let up on the peddle and it'll shift into 2nd then be sure to roll back into it so you don't slow down too much and bogg down the engine.
    Sounds dumb but it works, I've been doing that for over 6 months at about 20 miles a day for work and school. Oh that and Lucas Oil Transmisison stop slip helped me.
    -Avery
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that is not true for the ones that were put behind 4.3 V6's, they are the same as one that would be in a truck. i know of quiet a few that have no problem behind a v8 you have to remember the 4.3 was rated higher in power than most of the mid 80's 350's
  8. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    my 700r4 wouldn't shift out of 1st and all it ended up being was a stuck governor valve maybe yours is sticking. took mine out cleaned it and it was good to go.
  9. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    That doesn't sound like the transmission is going; I would check/replace the TV (detent) cable and make sure it is adjusted properly first. I've had this same thing happen to me and it turned out to be a siezed up TV cable.
  10. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    thanks for all the good info guys.......The tv cable is adjusted correctly and is in great working shape. I do wonder about the govner that the guy mentioned above????
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As said above check or replace the Governor. It is a cheap and easy job.
    Not shifting out of 1st is a classic bad or stripped governor problem.
