86 K5 with the 305
Discussion in 'The Garage' started by wattzk5, Mar 15, 2007.
  1. wattzk5
    wattzk5 Registered Member
    Jul 14, 2005
    9
    dallas
    Hey guys I have a 86 K5 that I recenlty lifted a put 36 Iroks on. Even before I lifted it and installed the new tires I have had problems with power and bogging down. Even when it was stock on 29's, 4HI was basically usless I was just puttin around the trail. Anytime I would get into a mudhole filled with some water i would just bog down so bad that i tires would be barely spinning. This is stock tires now.
    Slap it in 4LO and its got good crawling power even with the 36's and stock 3.08's. But once again if I plunge into a mudhole the damn thing will bog down so bad that the tires are serious barely even turning.
    I know i need 4.56's which are going in it next week but what else could it be?
    Is the motor shot, need a new fuel pump, or am I taking in water through the intake?
    Even if I am taking on water through the intake, there is still a problem b/c something i can floor this thing only highway and it will barely move.
    The last mudhole I went it last week i positive i took on water b/c it bogged down then started running really rough and then wouldnt start for a min. Then once it started water came shootin out the tailpipes.
    I rarely ever have any problems starting the thing. It usually takes a few pump on the gas pedal and it cranks over and run very smooth. Im pretty sure im in need of a new carb b/c i leaks fuel occasionally.
    Sorry for the life story. Any help is appreciated!!!
  2. 1990k5fan
    1990k5fan 1/2 ton status
    Jul 7, 2006
    217
    Gilroy, CA
    The problem is that your motor isn't built to beable to power those big tires with that low gear ratio. Don't feel bad about passing on the freeway, the 350 model isn't very good at that either.
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Do a tune up on the motor. Check your timing, check for vacum leaks, Fix the fuel leak. I have a feeling you got water in the dizzy instead of enough water in the intake that it actually injested enough water to push it out the exhaust in liquid form. Hydro-lock should have set in before this. If you think your engine is worn out get a compression tester and check pressure on each cylinder as well as doing a leak down test. Your truck bogging down with 36's isn't a shock but you should be able to spin 29" tall tires all day long.
  4. wattzk5
    Jul 14, 2005
    9
    dallas
    What is the dizzy???
  5. resurrected_jimmy
    May 23, 2005
    2,241
  6. wattzk5
    Jul 14, 2005
    9
    dallas
    Hmmmm yea my friend was like your distributor probably got wet....this is when it would start and was running ****ty right b4 water came out the pipes. So what do I do if Im taking in water through there?
  7. wattzk5
    Jul 14, 2005
    9
    dallas
    And what is a leak down test?
  8. resurrected_jimmy
    May 23, 2005
    2,241
    you can seal up the distributor by making a silicone seal where the cap goes on. There is a whole thread on here not more thana week old about waterproofing. Use the search feature to find it. I posted in that thread. You can pop the cap off and look under there to see if its moist. If so dry it out by spraying with WD-40. This is the most likely source of your rough running in the mud but probably has very little to do with your overall power problem
  9. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    RJ you noob, non-paying members can't search :p: . But if it's not that old you can scan through the first few pages, or someone could search for it, for you... Oh yeah you're motor is lacking power because the "0" and the "5" need to switch places... :D
  10. wattzk5
    Jul 14, 2005
    9
    dallas
    I was a paying member last year if that counts! I got out of this for a while and I'm just now getting back into it!
  11. resurrected_jimmy
    May 23, 2005
    2,241
    http://coloradok5.com/forums/showthread.php?t=201746&highlight=waterproofing must i do everything :rolleyes:
    I still think something is going on with it since he couldn't spin stock tires (29") in the mud
  12. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Tune up and fuel pump. Carb could use a tuneing(sp?) too . Sounds a little like your tranny may be slipping as well. Check the fluid.
    The 4.56's will help. My 305 is no BB, but it does good, and has since I bought the truck. It's a rebuild, has a Performer intake, ACCEL super HEI, and true duals though:wink1:
    John
  13. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    im running a 305 in my 85, it does really good. accelerates fine and gets through lots of stuff. i changed the plug wires, plugs, air filter, oil change, and just rebuilt the carb. i dont think i can get it running any better with 110k on it.
  14. wattzk5
    Jul 14, 2005
    9
    dallas
    Let me reword that.....I could spin the tires in the mud with the stock 29's but somtimes the motor would seem to bog down especially when I got deep
  15. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    could also be a plugged cat.
  16. 1990k5fan
    Jul 7, 2006
    217
    Gilroy, CA
    Haha yeah. That was why my motor wasn't running to its true potential.
    Changed the fuel filter and the cat and now it runs like new. Amazing the difference in performance between a clogged and new cat. :]
    Good luck.
