86 To 75 Conversion help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by conoverbandit, Jan 5, 2003.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    Conover N.C
    Ok I'm "researching" my avenues here, Any one put a newer type body on an older type chassis? Tips,Tricks?
    The reason being, the 86's frame is messed up. The 75 on the other hand has good frame rails just a body that's seen it's better days.I'm still partial to the 75 though,(full convertible&no emissions /forums/images/graemlins/grin.gif) But would like to hear from anyone that's done something like this. Thanks, Conoverbandit
  2. cybrfire
    Dec 15, 2002
    There is a cross member that will be in the way. You will have to run some sort of a body lift to keep the newer tub from sitting right on top of the older frame. Even if you remove the crossmember that hits you will still need a bodylift. Just make sure you replace the crossmember with a cross member that is lower. This is what I ran into anyway.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    Sacramento, CA
    I am guessing yours is the blazer we saw a day or 2 ago that has body cancer that ate almost all of the rear fender.
    If the body on the inside is OK I would just cut all the cancer and fill the void with some rubber meaning big tires /forums/images/graemlins/thumb.gif
    If if you still want to do the body swap, I would put a body lift or cut the middle cross member and adjut the body mounts to fit.
