86 Toyota help
Discussion in 'The Garage' started by crash1369, Mar 22, 2007.
  1. crash1369
    crash1369 1/2 ton status
    Dec 12, 2005
    207
    Tobyhanna, PA
    Ok so a guy i work with has an 86 toyota truck. he brought it to a mechanic that I'm pretty sure is either a crook or just doesn't know what hes doing but I'm leaning towards the first. Anyway the horn didn't work most likely due to the after market steering wheel so the guy put in a new button on the dash to work the horn. now the hazard lights don't work the guy said he thinks its missing a relay which is probably true because he probably took it out. i just wanted to verify this so i can get a replacement if thats actually the problem. if you push the hazard switch nothing happens but if you turn on the turn signals while the hazards are "on" they don't work so i don't know if that means theres a relay problem or not. if any of you guys know anything about these trucks that would be great. thanks allot
  2. crash1369
    Dec 12, 2005
    207
    Tobyhanna, PA
    nobody knows anything about these trucks?
  3. SUB602
    SUB602 1/2 ton status
    Jan 18, 2007
    407
    PHX, AZ
    The quickest and cheapest way to find out about the relay would be to replace it yourself. They are only a couple of bucks if that. Now did the hazard lights work before you took the truck to this guy?
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I'm thinking hazard FLASHER.
  5. SUB602
    Jan 18, 2007
    407
    PHX, AZ
    Are the Hazard lights on and not flashing or completely inop?
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    On my 82 Toyota, there is a horn relay as well as a hazard relay mounted to the fuse block on the firewall, maybe he's missing his relay, or it's loose.
  7. crash1369
    Dec 12, 2005
    207
    Tobyhanna, PA
    thanks allot guys, so there is a relay thats probably it then. do i need to know anything to get one or can i just tell them hazard relay?
