87 14bff hub nut question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Aug 12, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    /forums/images/graemlins/1zhelp.gifhow do you set this up? is it like the front tighten than back 1/4 turn its the single nut setup with the 1/4 key stock to lock it with the c-clip that goes arount the axel threads, thanks alot,
    dale
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Yep you set it up just like any other adjusting nut.
    Crank it down, back it off, torque it and back it off.
    Install lock and clip.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    cool man thanks alot,
    dale
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    like setting wheel bearings, torque/preload then back off til zero lash basically
    good luck
