87 350 motor AC comp brackets, hose manifold, etc
Discussion in 'Parts & Trucks Wanted' started by azblazor, Apr 12, 2006.
  1. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Want 87 350 motor - AC compressor brackets.
    Also the hose manifold, i.e. the hose assembly that mounts to the back of the compressor and goes to the accumulator and to the evaporator. Basically all underhood hoses/fittings.
  2. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    if a 87 305 is the same i might be able to help
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    How soon do you need it? I have an 87 Burb that I will be parting out in a few weeks and will let all the AC stuff go pretty cheap.
  4. azblazor
    May 5, 2001
    1,953
    I don't need the AC stuff immediatly. The 305 engine accesories should be the same as the 350 as far as I know.
    The Suburban has different compressor (hence brackets) and hoses if it's a dual air setup.
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
  6. azblazor
    May 5, 2001
    1,953
    still looking
  7. k2mslskier
    k2mslskier 1/2 ton status
    Feb 18, 2005
    1,524
    Tucson, AZ
    I'm not sure whether or not it would work for you but I have pretty much all the a/c stuff in my 80 that's just sitting there you can have if you want it. The compressor is on the driver's side if that helps.
  8. azblazor
    May 5, 2001
    1,953
    WOuld it be possible to get a picture of the brackets/AC compressor? If I drive down and take it I'll give you some money for it. PM me your phone number and I'll call you.
  9. k2mslskier
    Feb 18, 2005
    1,524
    Tucson, AZ
    pm sent.
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have an 88 blazer I'm cutting up. 350 eng. I can get you all that you need.
