87' 350 TBI intermintent check engine light and misses
Discussion in 'The Garage' started by fast-eagle, Jul 28, 2005.
  1. fast-eagle
    fast-eagle Newbie
    Jul 28, 2005
    Tomball, Texas
    I have a 87' Chevy K5 Blazer w/ 350 TBI. While driving it I have had the check engine light come on, followed by engine miss firing. This occurs out of the blue and usually lasts 30 seconds to a minute each time. The rest of the time it runs just fine. It seems to be pointing to a elctronic module failure of sorts. Anyone have any experience with this kind of problem before? Any help would be greatly appreciated. :1zhelp:
  2. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    check to see if it is throwing any codes. that may point you in the right direction.
  3. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    My guess is the egr code and the computer ignition control. I have the same problem. My Egr is only a year old, I keep meening to check it out, but its currently running and its hot out.
    Just wondering does yours happen more often in OD or when you get on the gas hard?
    If you figure it out first please post. I will do the same.
  4. fast-eagle
    fast-eagle Newbie
    Jul 28, 2005
    Tomball, Texas
    I will have to see if they are hard codes that will stay in the system, or if they are soft ones that are lost when the condition goes away.
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I had a similar problem in my truck. It has the full computer controlled carb. It turned out to be a bad ignition module. Changed it, and have had no problems since! :waytogo:
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Any trouble code is stored. Soft codes are not lost when the CEL goes out.
    So check your codes.
    If there are no trouble codes stored. Then your problem is most likely the distributor module.
