87 350 TBI timing troubles
Discussion in 'The Garage' started by Suprzuk, Feb 9, 2006.
  1. Suprzuk
    Suprzuk Registered Member
    Nov 28, 2005
    Catskills of NY
    Just got everything back together from replacing the intake gaskets. Truck fired right off the other night. I got to timing it last night. I disconnected the wire that I think is the advance coming from the ECM......(the wire looped out of the wire loom and back in below the brake booster). If I try to get the mark on the balancer down in front of the timing plate it will stall the truck out. If I leave the mark about 1/4" CCW of the plate the truck runs great.
    What could be causing this? Did I not disconnect the correct wire? Am I off a tooth on the dist gear? TIA for any help.
