87 350 w/ tbi bogging down
Discussion in 'The Garage' started by blackguns, Aug 26, 2005.
  1. blackguns
    blackguns Newbie
    Aug 26, 2005
    4
    PA
    Hello all. I hope someone here can help me out. I've got an 87 Blazer with tbi and when I really get on the gas, the engine bogs down, has no power, then slowly creeps back up. I've seen this problem a few other places but no solutions. So far here's what I've replaced: Fuel filter, fuel pump, plugs, wires, distributor, coil, coolant temp sensor and the gasket under the tbi. I advanced the timing and had two voodoo witchdoctors speak some unholy words with dead chickens. Sorry bout that last part but I think that's next. My next plan is to replace the fuel regulator in the tbi. Any help would be great. Thanks in advance.
  2. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    sounds like the O2 sensor to me...
    Is it throwing any codes?
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    What gear ratio and size tires do you have?
    What size engine and how many miles?
  4. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    says 350 in his title...
    If you stomp on the gas and it bogs when it should downshift it could be the tv cable also...
    My guess is the o2.
  5. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    :doah::doah::doah:
    I must be getting tired.
  6. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    revisited so i just bought an 89 and love it but when i punch it the trany down shifts and the engine bogs un til i let off a little im new to tbi so any ideas help
  7. blackguns
    blackguns Newbie
    Aug 26, 2005
    4
    PA
    Hey Oats, that is a lovely experience isn't it? Also, it wasn't the O2 sensor either. I just picked up 2 new (to me) tbi units for $40 so I figure I'll start screwing around with those soon. My truck still has the same problems but I'm building up one Hell of an xtra parts bin. If you happen to figure this one out, I would be eternally greatful if you'd let me in on the secret. I promise to do the same. Take it easy
  8. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    hey man you know it il pass it on
  9. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    what shape is your exhuast in good or bad im wondering i found in another post that backpressure may or may not be causeing trouble and the muffler on mine is fried just a thought
  10. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i have the same prob too. anone else have an idea???
  11. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    my sub does the same. i think its just the nature of the beast (tbi). they aren't hotrods to begin with, and after 200k miles, power is lacking. i do have 3.42's and 31", but i live with it...for now.
  12. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    An engine needing a tune would bog like you describe, but you'fe replaced most regular tune up items. Timing is controlled by the computer, so that should be good. A fuel pressure problem could cause it, but I wouldn't start with the regulator. If you can measure pressure at the TBI inlet would be the best. I would suspect a clogged sock in the tank, or filter (although I'm sure you've replaced that). Measuring fuel pressure under a load may show you a problem getting enough fuel to the TBI to maintain pressure. Checking with a gage has to be easier than dropping the tank to replace that sock.
  13. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    sweet thanx mouse
  14. kram
    kram Registered Member
    May 29, 2005
    54
    Edison n.j.
    if ya can get high rpm's i can't be plugged exhaust or lack of fuel???
    some thing to do with wot (wide open throttle).
    egr should cut off,est should change the timming to the extream.
    maybey the tps has a dead spot or map sensor bad/kinked vac line.
    my egr sticks open and gives rough off idle bog.
  15. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    thanx for the insite i got to thinkin bout what mouse said i use to own a heep xj and got rid of it but any wya it had the 4.0 it had the same symptoms sp? anyway it ended up being the fuel pump
  16. blackguns
    blackguns Newbie
    Aug 26, 2005
    4
    PA
    Problem solved
    Well Goddamn! Finally, after too much time and hundreds of dollars of $40 parts it's solved. Dirtwarrior17 was right. It was the TV cable. Didn't really even have any slop in it but after really working the release in and out with a screwdriver and readjusting the cable a couple times it's working great! I also found a good sized hammer repeatedly smashed on the bracket holding both cables just plain old made me feel better. I hope this helps anyone having this problem. The only downside is now that it's got it's balls back, I have to worry about the chipped gears in the ass end. At least I'm never bored. Thanks all!
  17. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
