87-91 Air Cleaner Thermostatic Valve
Discussion in 'The Garage' started by rcamacho, Apr 1, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Anyone know how the later model EFI Air cleaner cans work? The thermostatic valve has a plunger which opens the valve, but there does not appear to be any electric of vacuum connection to power it. Is there some sort of internal heat energized spring that activates the plunger?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My shop manuals are packed away, but as I recall there is some type of wax inside that expands and contracts as the temp changes.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks Harry.
  4. dyeager535
    26,979
    Yep. There is a post on the board where it was explained and a scan of the manual posted. Wax pellet sort of actuator.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks.
    I verified that the sensor is working so it appears to be a non-issue other than for info.
