87-95 SBC questions.
Discussion in 'The Garage' started by MOABDADC22, Oct 30, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Ok, I have built many, many SBC's and BBC's in my day.............but I have a few questions about parts interchanging. I know the crankshaft, one piece rear main, flexplate, and valve covers are different on 87-95 blocks.
    How about the intakes?? Will any non-TBI/TPI SBC intake bolt onto the 87-95 block and heads?
    Will a standard rotation (non-serpentine) SBC water pump work?
    Any help or suggestions will be greatly appreciated. /forums/images/graemlins/thumb.gif
    P.S. The casting # is 14093638
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The intake pattern is different if using the newer heads. An older style of head can be used on that block though. Aftermarket heads can be had with any type intake pattern you desire.
    Intakes can be made to work with these heads, if you are wanting to use the earlier style....
