87-95 tbi motor
Discussion in 'New England Region' started by NEK5, Nov 24, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anyone got one? need one to replace the POS in my blazer....i believe the year range is 87-95?
  2. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Not a TBI motor but I have a 'Heco' crate motor with low miles on it sitting in my garage doing nothing.
    It's a 350.
    I believe the head angles are the same...not positive though.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I most likely wouldn`t be able to put my tbi set up on it?...
  4. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    I think your right, changed in 87.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have a GREAT deal for you. I have a low milage 350 ci engine (25-30K) in my 88 parts blazer. Ran AWESOME. I gotta get this truck out and gone THIS WEEKEND. You wanna come and get it 300.00! It huffs a little smoke on start up, but it sat around most the summers when i did drive it. I have the valve seals for it. It was mostly just a plow truck. I was saving the engine as a spare for my 89, but thats sold without it! NEED it out of the garage. Call me. 518-225-3930, or 518-280-1121. Or give me your Phone, I'll call you.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    bablazer, i`d love to jump on that deal...but two things..1) i have the money, but right now its going towards a tranny and 2) wouldnt be able to get there this weekend
  7. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Buy my Blazer save yourself some money and get a better motor. :D
  8. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Is it $300.00 for everything?
    Like, load it on the trailer and go kinda deal? :thinking:
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hey jump on that man!
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hmm, need a little more info......PM me
  11. the beast
    Oct 15, 2003
    535
    Providence, RI
    All Pm's replied too.....:eek1:
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    more PMs sent:D
  13. the beast
    Oct 15, 2003
    535
    Providence, RI
    more PM's replied too.....:eek1:
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    how much? any idea how i could make my tbi work on it?
    EDIT: still looking, the deal with the beast fell through, so show me whatcha got!
  15. the beast
    Oct 15, 2003
    535
    Providence, RI
    Sorry bout that Ben.
    As long as the heads are designed for 1986 and up, you should be fine. You'll probably have to swap over your intake and TBI stuff.
  16. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hey np man, $hit happens, i should be used to it by now.....
    which motor are you referring to? any motor, or vtblazers crate motor??? if just swapping over my current intake and TBI stuff is all it takes to get it to work, i`m all for it!
  17. the beast
    Oct 15, 2003
    535
    Providence, RI
    As long as the motor is for 1986 an up, you'll just need to swap over your intake and TBI stuff. Other than that you'll probably have to swap heads over too. After 1986 they drilled the middle intake bolts at a different angle than pre 86. You can actually re-drill older heads to work with newer intakes, but usually not worth the trouble. Or you use a pre 86 motor and get an adapter plate to mount your TBI body to an regular aftermarket 4bbl intake. I think both Holly and edelbrock make them.
  18. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    question...with said adapter, i can run my tbi with no problems?
  19. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i cant seem to find them, got a link or part#?
    TIA
  20. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    are you looking to rebuild a motor or swap one in?
