87 blazer-fullsize rear window help
Discussion in 'The Garage' started by alfieboy, May 29, 2005.
  1. alfieboy
    alfieboy Registered Member
    May 29, 2005
    11
    VA
    Anyone know ehere I can get a rear window drive cable.. Im stranded an dcannot get the glass to go up or down.. unbolted glass..manually push it up..gears locked tight.. no way to really blacok it so it wont fall..
    Help please .. email or call me..ILl call back so no LD is incurred! 804-283-1951
    ...also need to replace the rubber gasket to stop the rain from going inbetween the glass and tailgate.....
    thanks
    Rick
    :frown1: :frown1: :frown1: :frown1:
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    get a can of PB Buster or two and spray the sh** outta the arm linkage, that'll free it up enough to unbolt only the drive gear in the top left corner (3 bolts and knock it rearward). You can then manually move the window up and down... use a bungee to hold it down, and bolt the drive gear back in to lock it up.
    I had the same problem, and right now that was my solution until i can find said cable for myself :)
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    hey, since i have an 87 too i will ask my question. when i had the tail gate on, the window wouldnt go all the way down, it would have about an inch left and wouldnt go anymore. is this normal? or is it messed up somewhere?
  4. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    it's normal
  5. alfieboy
    May 29, 2005
    11
    VA
    window
    stuck a 2x6 in in for now to hold up..(unbolted tracks.....).. no sense in unbolting gears..
    bu tnow to find the damn cable.....
  6. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    What i was talking about was the drive gear that the cable attaches to, if you take out the three bolts and give it a good poke it just gets behind the left (as you look at it) gear/arm and mount, and to put it back you just reach around and grab it, line up the 3 holes and thread the bolts in... 3/8" socket and ~2" extension is all you need
