'87 blazer noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mattyblazer, Sep 27, 2002.
  1. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    \'87 blazer noise
    Can someone tell me what the thumping noise that comes from under the floor near the t-case is, and how to stop it.
    If I gas the truck hard from a stop I get a rapid thump, thump, thump through the floor.
    Matt
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: \'87 blazer noise
    U-joint?
  3. mattyblazer
    Sep 22, 2002
    202
    Long Island, NY
    I got new u-joints, transmission + mounts, t-case mounts, and the shafts were just balanced.
    But Thanks
    Matt
  4. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    how about axle wrap??? like the springs might be unloading when your giving it gas!!! ??? just a guess
    Ck1500
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    What kink of trany mount did you get? rubber or Poly? Sounds like eather the old body mounts are bad and the new trans mount makes the t-case shifter or t-case to hit the floor board.
    Also check the exhause for excessive movement. The mounts sometimes get destroid and then it bangs on the udner carage.
  6. mattyblazer
    Sep 22, 2002
    202
    Long Island, NY
    I put rubber transmission mounts in, and thanks guys I will look at your suggestions.
    Matt
