87 Burban Help
Discussion in 'The Garage' started by bhill1429, Dec 21, 2004.
  1. bhill1429
    bhill1429 Newbie
    Apr 13, 2004
    3
    hi all just got my hands on a 87 suburban with a 6 inch lift and putting 36 tsl radials on it... But have some question and was hoping that this would be a good place to start...
    How to tell what gears are in it??
    What are the advanages to the TBI?
    Should I convert to a carb??
    Would like to add a spare tire swing out on the rear any sugestions other than fabing one??
    Any Help would be great
    Bobby
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    You can tell the gears by checking the axel tag its usually bolted to one of the diff covers. If not you will need to pull one of the covers and get the number of teeth off the pinion and ring gear.
    The advantages of TBI are easy starting and that it will runn at any angle off road. I think that unless you are planing on radicaly modifying the engine than you should stick with the tbi. The systems can be modified to make good horsepower. And as far as the tire carryer im not to sure other than making your own. Hope this helps
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The codes on the glovebox sticker are the best way to find out the ratio without getting your hands dirty. The relevant codes start with 'G'. GM products tend not to have axle tags... unless its a Dana axle.
  4. bhill1429
    bhill1429 Newbie
    Apr 13, 2004
    3
    Wanted to say thanks to the 2 that sent me in the right direction...
    Here is what the Glove box had
    GQ1
    GU6
    G80
    Thanks Again
    Bobby
  5. bhill1429
    bhill1429 Newbie
    Apr 13, 2004
    3
    After a few minutes on the Net here is what I found
    GQ1 : AXLE, STD RATIO
    GU6 : AXLE REAR, 3.42 RATIO
    G80 : AXLE POSITRACTION, LIMITED SLIP
    found it on http://www.thirdgen.org/cgi-bin/rpo/index
  6. dyeager535
    26,975
    If thats a half ton, be careful with that rear axle and those 36's! :blush:
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Keep the TBI!
    Carbs are great for muscle cars and mud trucks, but that's it IMO.
