87 Chevy 3/4 ton van rear axle . . . will it fit a chevy PU???
Discussion in 'The Garage' started by ratchetmaster, Jan 18, 2005.
  1. ratchetmaster
    ratchetmaster Registered Member
    Mar 26, 2003
    47
    PLEASANT GROVE, UTAH U.S.A.
    I have an 87 3/4 ton van that I am going to part out . . . can't get anyone to give me $600 . . . had it in the paper for 4 weeks
    so I am going to part it out and scrap the rest. I will keep the engine and turbo 400 trans but what about the rear axle?? will it bolt into a pu?? I think it is a corporate 14 bolt.
    Tim
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah it should fit. I have a van rear in the back of the Jimmy. Only thing I had to do was relocate the spring pads. Van widths are usually 3" wider than a truck rear so you don't need spacers on the tires to correct track width.
  3. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    WOW!i didn't know that.good info to have.probably never use the info...but good to have just the same.thanks!
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep relocate spring pads and shock mounts
    is it an FF or SF ?
    most likely an SF if an 87 but could be FF if has HD springs option, etc
  5. ratchetmaster
    Mar 26, 2003
    47
    Thanks for the info . . . good stuff to know.
    IT is definitely HD because it is set up to haul 12 passengers . . . looks HD.
    I don't know what FF and SF is. Can you explain and then I can check it out and see.
    As I mentioned in another post, I found out it has the G80 or posi option. I don't know gears yet.
