87 chevy van parting it out. WHAT IS WORTH KEEPING FOR TRUCK PARTS??
Discussion in 'The Garage' started by ratchetmaster, Jan 21, 2005.
  1. ratchetmaster
    ratchetmaster Registered Member
    Mar 26, 2003
    47
    PLEASANT GROVE, UTAH U.S.A.
    I guess I have decided to part this van out . . . what parts are useful to use on trucks??
    the obvious stuff like engine and trans (350 TBI and turbo 400) but what other stuff will interchange with trucks??
    I don't want to scrap anything that can/will be useful.
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    does it have a double ujointed steering shaft?
  3. ratchetmaster
    Mar 26, 2003
    47
    I believe so . . . I will have to check. Worth keeping??
  4. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    keep all the good stuff!
    You might keep the radiator if its any good--not sure if it will fit a C or K series,but its possible,and big vans usually have big radiators...
    The rear leaf springs might be of some use too,if they dont fit your truck you could use the leaves for helpers,or sell them to someone for more than scrap value if they are in decent shape...other than that,little things like headlight switches,heater blower motor and resistor,might be interchangeable,I rob all the bulbs and fuses out of the trucks I scrap,you can never have too many of them kicking around ...I even kept an entire wiring harness out of a few rucks--saved my butt when I had a wire fire ,and I've been cutting plugs and peices of wire off another for years,Its nice to have that weird factory plug you need for the altenator,etc..and the wires color codes will still match if you need to splice in a new section of wire..if it has a good radio,thats a keeper too!....:crazy:
  5. ratchetmaster
    Mar 26, 2003
    47
    Thanks so far.
    I am kinda suprized. . . thought there would have been more guys that had robbed/saved parts from vans before.
    Still looking for input. Anyone else???
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    spring hangers for flips, hell maybe it has good bukit seats?
    oh yank the windsheald washer pump and tank i have two on my truck:waytogo:
    never run out
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I would keep the rear end ( if it is a 14FF) most folks like the wider Van versions .
    The power steering pump and resivour is supposed to be larger or atleast more capacity .
    Check to see if the blower motor is the same dimensions as the truck stuff ( might be a stronger motor in a van) ????
    HTH's , Tom
  8. ratchetmaster
    Mar 26, 2003
    47
    well, finally going to scrap this van . . . I have been too busy to deal with it.
    any final imput on other stuff to keep?
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    windshield and radiator springs are not same as pickups and such
    radiators narrower
    springs too long
    windshield way too large
    ive had many '74-'79 chebby vans, all utility or passenger ones, and even a '79 schoolbus dually G30 one, most i drove til was bored with them then i parted them, been through this many times :P
    good luck
