87 duallie axles
Discussion in 'The Garage' started by Tra 23, Mar 4, 2006.
  1. Tra 23
    Tra 23 Registered Member
    Jul 6, 2005
    9
    Evansville, IN
    I found a great deal on an 87 3500 4x4 chassis. I'm not sure about two things -
    1. Is the rear axle in a duallie truck the same length as that in a srw truck? The thing is far enough away that it's not convenient to just go measure it.
    2. What's involved in changing the front axle to fit a blazer?
    Any help would be appreciated.
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I would really like to know the answer to that question too.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If it is a pickup truck and not a cab and chassis then yes the rear is wider than a SRW truck. If it is a pickup those axles are perfect to run stock H1 beadlocks on.:D Should be a Dana60 front with a Dana 70 rear, It could be a wide 14FF though either one is the same width on a dually pickup. If you put SRW hubs from a rear axle on the wide axle the track width will be the same front and rear.
    Ira
