87 F150 2wd Springs
Discussion in 'The Garage' started by wayne, Jul 12, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I found an 87 with the 4 plus overload rear springs. Are those the ones I want to get????? /forums/images/icons/confused.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Check the width. If they are 2.5" wide, then, yes, those are the ones you want.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    What BadDog said!
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    They are 2.5. /forums/images/icons/grin.gif
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Ok, I got the springs, nice tail gate, and some other misc parts for $175. /forums/images/icons/cool.gif
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    /forums/images/icons/laugh.gif Have fun!
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've been looking for a good electric tail gate... problem is most of them are broken. Good score on the leaf packs. So when are you going to put them on?
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is required to install the ferd springs, I have your shackle flip, what elso do i need?
  9. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I picked up my 57's for $60. I spent more on epoxy paint, u-bolts, center bolts and new UHMV pads than I did for the springs...should be cool when it's done though. /forums/images/icons/cool.gif
    Rene
  10. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    A 6" shackle and re-drill the ford pack 1 1/2" back (the maximum to remain under the spring plate) to center the axle. With the shackle brackets, run them on opposite sides which places the shackle mount 1" back rather than 1" forward and your ready to bolt everything in.
  11. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Does anybody know what size bushings the ford springs take. I would like to get a set and need to know what greasable bushings to order.
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    1.50 and 1.25 the eyes are different.
    if you scroll through post in the for sale furom on his brackets he has it listed in there when I asked.....let me go get the post.
    ford info
    We really need a tech write up on this as for what years and heigth works and what all is need to get them in there.
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    would it be possible to redrill the whole pack??
    also what needs to be added to them to make the right heigth??
  14. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I'm redrilling my whole leaf pack right now...one spring at a time. I need a bench grinder to dress my drill bits though. They tend to suck right out of the package...
    I'll take some step by step pic's...combined with whatever Borrego and Marv have we should be able to come up with something decent.
    For reference the springs I got were the 57" x 2.5" wide 4 leaf plus the overload F-150 springs. I'll let you know how much the height changes. I'm moving my rear hanger back 3", building another rear shackle (approx 6") and doing a poor mans flip by cutting out the bottom/rear of the hanger and gusseting it.
    Rene
  15. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I redrilled my whole pack this time around based on Marv's experience, only I drill pressed them all at once (sorry Rene, thats too much work for me /forums/images/icons/laugh.gif ). I would reccommend you drill all the leaves and not just the main. My last set didn't do so well after flipping the overload with only the main leaf drilled... was a hybrid pack too so that may have contributed to its fatigue. With the weight of the truck on the springs they should give you stock height, but this assumes the hanger is in the right spot. With the various ways people are getting flipped and relocated, there are going to be lots of varying results on lift height.
    I'd definately like to see and contribute to 57" spring swap tech article.
  16. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I would have drilled the whole pack at once but I'm limited to my poor old 1/2" Craftsman hand drill and a block of wood on my patio. One at a time was easier! Took me a little over an hour to drill all 10 leafs.
    I'll be snapping a few pic's as I go. Now I have to finish cleaning them and give them a good coat of epoxy paint.
    Rene
  17. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I am not planning to drill the packs. I have offset zero rates to eliminate that problem. I have a set of ORD shackel flip brackets that I will use. All I need to get are bushings if the ones I have now won't fit. I also need a set of longer shackels. When we pulled the springs I couldn't believe how much the sprang apart. /forums/images/icons/grin.gif Not sure when I will be putting them in.
  18. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I would have liked to paint my springs this time, but after around 8-9 times looking for good combos, I was ready just to slap them in and see what happens!
    Those ORD offsets would definately make the job easier.. almost like cheating! /forums/images/icons/wink.gif
  19. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    anyone know the stock spring rating?? versus the fords...was thinking someone said the fords are only like 198#s or so. I'm losing about 1,000 pounds with the body swap and need as soft a spring as i can get.
    And i plan to redrill the whole pack and use my 1" zero rates
  20. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Should I get shackels that are 2" longer then stock?
