87 idle problem
Discussion in 'The Garage' started by Rescuedad77, Sep 16, 2006.
  1. Rescuedad77
    Rescuedad77 Registered Member
    Sep 14, 2006
    17
    Bellevue NE
    I just swapped my 87 GMC jimmy tbi 350 with an 81 350 block and cannot seem to get the timing right, I have brought it to three different mechanics around town who cannot seem to figure it out. One did tell me that the cam in the 81 block will not work in the 87 tbi setup because of the computer needs to be reprogramed. I called jegs up and they told me the computer cannot be programmed for that cam does anyone have ideas. Thanks!:bow:
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You'll have to either get the correct TBI camshaft or have a custom computer chip made to work with your non-TBI camshaft.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I swapped a TBI unit on my 86 with the stock cam, and it ran just fine. I timed it to 4 degrees BTDC. My 86 spec (stock) was 6 degrees, and TBI is supposed to be set to 0 degrees. But mine seemed to work best at 4 degrees. Are you unplugging the brown wire before you try and set timing?
  4. Rescuedad77
    Sep 14, 2006
    17
    Bellevue NE
    Yes, the weird part of it is at idle it runs like crap anything over ten miles per hour it purs like a kitten.
  5. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    You didn't set initial timing with the distributor plugged into the computer did you? I seem to remember having to unplug it to set it to 0* without the computer retarding the crap out of it.
  6. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    are you sure it's not an EGR problem (stuck open?)? Is the computer throwing any codes?
  7. Rescuedad77
    Sep 14, 2006
    17
    Bellevue NE
    Chiltons told me to just unplug the brown and black wire.
  8. Rescuedad77
    Sep 14, 2006
    17
    Bellevue NE
    the computer isn't throwing any codes at all.
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Sounds like it could be a vacuum leak or an EGR problem. Have you checked all the vacuum lines for cracks, etc.? Try unplugging the vacuum line to the EGR and plugging it with a screw and see if the idle gets better. The chilton's book should have a test for the EGR valve itself too.
