'87 IROC 5.7l TPI or an '97 TBI 5.7l with Vortec heads?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72Blazerod, Nov 4, 2001.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    \'87 IROC 5.7l TPI or an \'97 TBI 5.7l with Vortec heads?
    Help me out here guys,
    I need to get a new engine for my '72 Blazer and I have a line on two. One in a 1987 5.7l IROC TPI with 85k miles. This one is missing its' MAF sensor.
    The other is a 1997 5.7L TBI with Vortec heads that has about 38k miles. Both are not too bad for price.
    Which would you choose? I really want to go fuel injection!
    Thanks for your help,
    Rod
    <a target="_blank" href=http://communities.msn.ca/72BlazerodsOldChevyTruckPage/photoalbums.msnw>http://communities.msn.ca/72BlazerodsOldChevyTruckPage/photoalbums.msnw</a>
  2. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Re: \'87 IROC 5.7l TPI or an \'97 TBI 5.7l with Vortec heads?
    I like the TPI, but those vortec engines are BAD ASS! If the price is close, definitely go with the vortec. Racers around here are taking them, putting a cam in them, a manifold and good carb, outrageous results.
    Drive it Like You Hate It!
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The 97 isnt TBI, its a Vortec multiport setup. It will be more work to install than a TPI.
  4. 72Blazerod
    May 18, 2000
    264
    This is the stuff I need to know, thanks!
    Could you let me know why is the '97 engine more work? What sorts of things would have to be done differently?
    Thanks for the help,
    Rod
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Alot more sensors. I would do the tune port and put a good set of aluminum heads if you are looking for power.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Go with the TPI, I did and I am very happy, I also had the chance to use a Vortec and opted for the TPI. Much more infor on the swap and much easier. More aftermarket stuff for the TPI and the TPI is the deal when it comes to torque.
    My opinion.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I would vote for TPI (big surprise [​IMG]). It will be easier to install and has lots of go-fast parts available. Love mine.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  8. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    i like the tpi personally i've got an 96 corvette lt-1 in mine and i love it, and if memory serves isn't the vortec a non sequential multi port, that is it has one injector that feeds all eight cylinders and the same time, insteed of one injector per cylinder?
    <font color=blue> If sancho knows what good for him, he best go run and hide. Cause daddy's got a new 45.</font color=blue>
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    MPI has 8 injectors
    Isn't sequential when it times the injection of each injector to the opening of that valve insted of batch firing them all at the same time?
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I don't know what's what here, but I know that there were some CPI (Central Port Injection) Vortec engines that used a single large injector. They're better controlled than the TBI setups, but still not quite as good as a batch-fire port injected setup and nowhere near as good as a true sequential port injected setup. If this Vortec is a CPI setup, I'd definitely go with the TPI even though it's missing its MAF sensor (easy to get, not too horribly expensive). If it's a true milti-port setup and the price is similar, I'd go with the Vortec. Of course, if you have a manual transmission, I'd go with the TPI engine either way because there aren't any good flywheels for the small register cranks on the Vortecs.
  11. 72Blazerod
    May 18, 2000
    264
    My Bad! Sorry, I don't know where I came up with the TBI thing. But what does make the muti-port system harder to install. Is there any info out there about retro-fitting one of these newer Chevy engine into another vehicle? There is a guy on a web page close to my home (www.bc4x4.com) that said he just pulled one of these from a '97 and can't wait to put it into his J%#P. All the guys on that site are telling me to go for the newer engine. I know we have a few engineers here on this page, why would the newer engine pose such problems?
    Also, what fly wheel did the 5-speed trucks of '98 use? Would that work on my truck? (I do have a SM465).
    Thanks guys,
    Rod
    &lt;a target="_blank" href=http://communities.msn.ca/72BlazerodsOldChevyTruckPage/photoalbums.msnw&gt;http://communities.msn.ca/72BlazerodsOldChevyTruckPage/photoalbums.msnw&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by 72Blazerod on 11/07/01 05:21 PM.</FONT></P>
  12. Steve_Chin
    Mar 6, 2001
    1,126
    The biggest difficulties in installing any of the newer model engines into an older vehicle revolve around packaging (where to put stuff) and execution (how to adapt things). The sensors and wiring really aren't all that bad in my mind. Where to put the ECM, relays, and some of the modules can be problematic in some cases (luckily, we have LOTS of room in the blazers!). I don't see where a '97 engine would be any harder to install than an '87 engine, other than the presence of a little more wiring and a couple of more sensors. In either case, you need to mount the ECM in a place where it's not going to get wet, vibrated to death, or bashed.
    FWIW, I used to work with a guy who put a new-ish F*rd 5.0 EFI engine into a J@@p (along with an NV4500). It was pretty sweet.
    Anyhow, the later trucks used an inertial-balance flywheel with the small register crank. The problem I see with it is that it only acceptsan 11" clutch. Not too big a deal to most, but since my Blazer originally came with a 12" clutch, that's what I want.
