87 jimmy Transmission
Discussion in 'The Garage' started by rescue1, Nov 2, 2003.
  1. rescue1
    rescue1 Registered Member
    Oct 30, 2003
    5
    i blew a rubber trans line that the previous owner had put on, and now it wont shift into overdrive,and it wont shift gears unless your at high rpms. did i blow something up or is it a quick fix? /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Did you add some ATF to make up for what was lost? If you haven't added any, there probably isn't enough fluid in there to create pressure for the shifts.
  3. azkfive
    azkfive Newbie
    Nov 3, 2003
    3
    rubber trans line?? the quick fix was the guy who put that on....anyway i agree with checkin the fluid. if u drove to long u might of burned it up
  4. rescue1
    Oct 30, 2003
    5
    fluid is full so i guess i toreit up. next question is,I have a turbo 350 trans will it bolt up to my transfer case?
