87 K5 10 Bolt Rear axle shaft bearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dgface, Oct 6, 2002.
  1. dgface
    dgface Registered Member
    May 12, 2002
    39
    McDade,Texas
    What tools do you need to remove the axle shaft bearing and is there an easy way to do so? /forums/images/graemlins/1zhelp.gif
  2. dyeager535
    26,980
    Slide hammer is how I did it, and also I believe if you do a search, someone posted another way to do it involving PVC pipe?
    Make sure its the problem though, its a real pain, and on top of that, if the axle is worn down (as they usually are) in my opinion you aren't doing much good, unless you use one of the "repair bearings" or replace the axle.
