87 K5 running lean?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87BrnRsd, Sep 16, 2004.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I have a 1987 K5 with a rebuilt 350, and tbi. Pretty much everything on the engine is stock. The truck is running pretty lean and I am wondering how to fix this. Sorry I havent given any more info, but I will pull the codes tomorrow to see if you guys can diagnose them. Thanks.
    -Harrison
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What makes you think it is running lean?
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    vaccuum leak?
  4. 87BrnRsd
    Apr 21, 2003
    2,457
    Unburned gas in the tip of the exhaust pipe.
    -Harrison
  5. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    unburned..?? I get H2O form/drip from my exhaust when shes tuned right...i'd think if you had unburned gas (rich?) and if ya have THAT much am surprised it runs...
  6. 87BrnRsd
    Apr 21, 2003
    2,457
    Its not THAT much. It doesnt drip. If you put your finger in the tip of the exhaust and pull it out, its moist and smells like gas. Its throwing a code, so I am getting ready to go check it now. Will let you know what it says.
    -Harrison
  7. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    the base gasket on for the tbi is common for leaking check for the o'2 sensor also
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I just went through something similar with the wifes truck. Was running lean, but the computer would dump fuel to try and comensate for it. The vacuum ports for the MAP sensor and PCV were plugged with carbon. the MAP wasn't getting a true reading. Cleaned them out and runs great now.
  9. 87BrnRsd
    Apr 21, 2003
    2,457
    Thanks! I did that and it runs good now. Problem fixed.
    -Harrison
  10. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Where is the MAP sensor on a 90 Blazer ?
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Right side of intake manifold, It's attached to a bracket thats just to the side of the Throttle body.
  12. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Thanks, I'll have to clean it..
    Dan...
