87 k5 stalling out
Discussion in 'The Garage' started by tommysblazer10, Jul 18, 2005.
  1. tommysblazer10
    tommysblazer10 Registered Member
    Oct 26, 2003
    9
    new jersey
    Looking to buy a 87 k5.It runs smooth for a about 2mins then hits a higher idle and then stalls out.I have to hold the aceelator to the floor to get het started but alot of times wont start.Get alot of black smoke out of exhaust ??Unburn fuel im guessing .. Any ideas?????
  2. weisers26
    weisers26 Registered Member
    Apr 14, 2005
    12
    Whitewood, Sask, Canada
    LOL,........ bud, once you get some answer's, I'll probably get some ideas too!! I'm going through the same damn problem. If you give it some fuel while driving, does it buck and cough, for a bit than die?? That's kinda what mine is doing and I think it my fuel pump. (Long story, short)My jackass neighbour went and turned the pot on the fuel pump and I think (ha, think, I know it has to be) it broke the seal, so I'm getting air into the fuel before the carb.
  3. dyeager535
    26,975
    Any codes?
  4. tommysblazer10
    Oct 26, 2003
    9
    new jersey
    Some guy looked at it and said a code 12 to much fuel
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    code 12
    If code 12 blinks more than 3 times then that means that there are no codes stored.
  6. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Hpw do you read the codes on a 1989?
    Eddie
  7. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    read codes
    You can either buy a key or a code reader from the parts store, or you can take a paper clip and bend it into a "u" shape and insert it into the top right two prongs on your andl connector under the dash. After inserting it turn the key on and watch the check engine light. It should flash code 12 3 times and any codes after that. It will flash all codes 3 times each and then go back to code 12 when finished.
