87 Sub. VSS?
Discussion in 'The Garage' started by Tux, Jan 14, 2006.
  1. Tux
    Tux Registered Member
    Jan 9, 2006
    14
    Phx
    I am putting a np203 behind a 700r4, unfortunately I do not have the original tcase to determine if it is supposed to have a vss. The engine is a tbi 350. If it requires a vss hooked to tcase anyone have an idea how i can accomplish this installation with out the factory tcase?
  2. eblick
    eblick 1/2 ton status
    Nov 7, 2004
    218
    Jacksonville
    Not too sure about your model but I have a 241 behind my 700r4 and the vehicle speed sensor runs off my spedometer in the dashboard with some sort of sensor mounted there.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Your VSS is run off of a reflector and light on the back of the speedometer inside the dash. Hooking up your speedo gears is just like any other vehicle with a drive gear a driven gear and a speedo cable to the back of the Speedo.
    Ira
  4. sandawgk5
    Oct 28, 2003
    6,881
    I want to say that 1989 is when they went to a reluctor ring and electronic speedo with a drac to provide a vss signal to the ECM.
    Ira
  5. Tux
    Jan 9, 2006
    14
    Phx
    Thanks for the information, I was worried about having to buy a different tcase.
  6. sandawgk5
    Oct 28, 2003
    6,881
    Na you would never have to buy a new Tcase. Jagsthatrun sells a signal generator that runs off of the standard speedo gear in the transmission but sends the electronic signal to feed the ecm and electronic speedo.
    Ira
  7. Tux
    Jan 9, 2006
    14
    Phx
    thats good to know as well
