87 Suburban project
Discussion in 'The Garage' started by texsub, Jan 7, 2007.
  1. texsub
    texsub Registered Member
    Jan 2, 2007
    20
    Amherst Texas
    This is what I have.
    87 Sub with off-road package (dual front shocks, steering stablizer ls rear diff and tow hooks 3.73 gears) 10 bolts f&r, old tired 350, rebuilt 700r4 little rust and recked interior.
    I want to build a jack of all trades truck(light towing mild off roading DD and family camping trips). I know that means master of none.
    My plan is to fit 35s-37s with 1" body lift and body mods. Then 2"-4" suspension lift for travel.
    My questions.
    The 350 rebuild or replace with a 6.2/6.5 or 4bt. I don't mind the power level the Sub has so better milage with equal power would work. Not sure how the larger tires will affect things though.
    I want a smoother ride so suspension sugestions... 4 link, soft ride springs???
    btw I have 31x10.5 on it now, but I'm putting some 33s (10.5f & 12.5r) next weekend.
    I would have posted in the Suburban forum but repairs ate my join funds so I have to wait a week or so to post there.
    Thanx in advance for your sugestions.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Best advice, IMO, is to spend a lot of time reading here. Then form a plan and determine what you really need. Things like 4-linking a Burb sound cool, but unless you really know what you are getting into and why you need it, it can be an even more frustrating money pit than it will be anyway.
  3. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
    I agree.
    My advice for you would be engine rebuild, 4inch suspension lift with softride springs. Get a good radial Mud terrain. That should get you started. Be able to wheel and go on trips.
    What gears are in it? You may want to regear if you are towing alot. Otherwise low range may be good for the wheeling you do. My brother has a 90 Suburban 350 T400 with 3:73 gears and 38 Super swampers and gets 13-15mpg with it.
  4. texsub
    Jan 2, 2007
    20
    Amherst Texas
  5. KingDuramax
    Jan 17, 2006
    451
    NY 14701
    Cool. Have fun reading.
  6. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Welcome to the site!!!
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Search my old posts in the Garage. I posted a thread with a spring part number that rides excellent. It is actually intended to be a pre-runner spring for a K5, but I have had my set under two different SBC Subs and they work great.
  8. cbbr
    Jul 17, 2004
    14,681
    He can't use the search function. Paying members only. But it is certainly worth the $25/yr for the amount of info you have access to.
  9. texsub
    Jan 2, 2007
    20
    Amherst Texas
    New big prob in the suburban project. My Limited slip (gov lock??) just went out in the rear 10 bolt. Now I have to find a way to patch it untill I can replace the rear. I have been concidering different replacement options, but I'm not ready for that yet. But now that it went out I have to do something.
  10. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I've got a similar project with an 89 Burb, pretty much the same set-up. I went with 4" superlift springs, they're nice and soft. I just put on 35" Mud Rovers, and with 3.73 gears my powerband went out the window. I think that with the heavy weight of the Burb, it needs 4.10, probably 4.56.
    I've been thinking of rebuilding to a 383 when the 350 engine goes out. It seems to me like a good choice for all around work/trail/camping truck.
  11. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Front: B-52's with stock rears in front = 4" link
    Rear: ORD/DIY4X 4" Shackle flip
    .02
