87 TBI 305 engine, water in oil, low radiator, bubbling in overflow tank
Discussion in 'The Garage' started by R72K5, Aug 24, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok in an 87 c-10 pickup with tbi 305 engine, the radiator is empty and water is in oil, oil level is up over full, and air is bubbling up back into the overflow container alot
    from your personal experience with this same engine, what did you find was the cause of this problem
    cracked hear or bad intake gasker or bad head gasket
    if i have to i will swap these 14014416 heads(85 c-10 58cc 305 heads) that i have on another engine onto it and use old style valve covers
    if the TBI exhaust manifolds will bolt to carb heads ?
    thanks
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Head Gasket
    Small Blocks Aren't Bad About Cracking Heads Unles You Have Ran It Very Very Hot. Most Likely You Have A Bad Head Gasket. I Would Pull The Head And Have Them Checked For Warpage And Crakes (just In Case) Replace The Gaskets And Run It.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    even the 87 tbi 305 heads arent good for cracking ? its been run hot and probably several times now, as it burns ALOT of water HUGE cloud of white smoke really bad
    i just now got here from driving it across town like this to get it to here, so i can yank heads off
    i wobnt spend the 60 to 100 to have them checked when i can just swap a pair of known to be good 305 heads on that i already have, even if they are not factory TBI ones,, i really dont care that they are not, lol i can make them fit and work just fine :D
    what do you think
    thanks
  4. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Head Gasket
    The Heads Will Bolt Up Fine To The Exhaust, But The Center Intake Bolt Holes Are At A Differant Angle. Therefor The Intake Holes Will Have To Be Drilled To Fit The Old Style Heads. Most Machine Shops Will Only Charge You 10-15 Bucks To Check And See If They Are Warped And You Can Look And Usually See If They Are Cracked. Resurfacing Around Here Is 30 Bucks. Unless You Drill The Intake Yourself It Will Cost You That Much To Have It Done.
    I Would Check Into The Prices Of Both Just To See What The Cheapest Way Out Is.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well fixing the middle intake bolt holes is free cuz ill slot them myself on the drill press, etc
    and either wya i know its gonna cost extra if i keep the tbi heads, unless it really was just the gaskets, but the odds of the heads not being warped or something are probably slim
    but i dunno
    i was hoping to find someone else who has been through this same exact thing to see where the problem was at exactly
    if with the heads, or if was just gaskets
    also i wonder if bubbling up in reservoir tank would be cause by head gaskets, or if could be caused by intake gasket or cracked head ?
    probably just from head gasket leak right ?
    no ?
    im trying to think,,
    i just sold the 88 caprice a few minutes ago, so im gonna go get gaskets and all that fun stuff, and yank the heads tomorrow, i started tonight on it
    thanks
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    heh, sounds like my 89's 305!
    More coolant came out of the oil pan than oil after I blew it up... It hydrolocked from the bottom side, broke something or other, and totally seized the engine up, lol
  7. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    hi i'm new and have never posted but i thought this would be a good time cause i had the same thing happen to my 350 crate motor. what had happened was one of the head bolts pulled the threads out of the block and let pressure off the gasket in that spot and blew the gasket.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sierra, hi, thats cool and all but did you know what the cause was ?
    head ?
    gasket ?
    intake?
    thanks
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Dan hi, welcome to the forum :D :thumb:
    ive been to AR once, wow you guys have crazy accent down there lemme tell you what! lol
    never had nor seen a head bolt do that
    thats pretty crappy
    that had to of been a crazy fluke
    damn.
    thanks
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    pull the head, and expect a cracked head. if its just a gasket, its better than you expected.
  11. Russell
    Jun 23, 2000
    7,923
    333
    I wasn't able to get the dizzy out of my motor, its jammed in there real good (I think there is a pushrod bent over infront of it or something)
    I am guessing headgasket though, it had been leaking for some time already (bubbles in the rad, but no water in the oil as far as I could tell) and it finally went when I was doing some compression braking on the way to the lake. I was about 5 minutes away and figured I could make it, then tow it home later, but there was a big hill, and despite my best efforts, the truck downshifted and went POOF. Two big clouds of white smoke (one from each tailpipe) and she was done!
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    beater, yep, either way it should be fine,
    sierra, poof,
    killed it for good ? that was it ?
    that sux
    thanks guys
