'87 TBI 350 in Blazer
Discussion in 'The Garage' started by pitbulls'n'blazers, Nov 27, 2006.
  1. pitbulls'n'blazers
    pitbulls'n'blazers Registered Member
    Jan 18, 2006
    67
    Missouri
    Hi I have a couple of questions about the stock 350 that's in my '87 Blazer. First is it a 2 or 4 bolt main engine? Also what is the cfm on the stock TBI?
    thanks!
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The block could be either a 2 or 4 bolt main. IIRC the factory TBI unit only flows 470 cfm
  3. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    Is there a way of telling if it's 2 or 4 bolt with out taking off the oil pan?
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Nope, must pull the pan to find out.
  5. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    I'll check it out when I change the oil. Thanks for your help!
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    uuuh, yeah, run the casting numbers on the rear driverside tab of the block,,,,,:confused:
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Only sometimes. allot of casting numbers are either/or.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Look at the vin number. To my knowledge in 87 the K5s only came with 2 bolt mains. The HD emissions engines could be either or but not the K5 engine.
    Ira
  9. dyeager535
    26,979
    If you get the chance and remember, when you find out, post the suffix code and whether two or four bolt in this thread. I'm trying (not very hard) to see if suffix codes can be used to determine two or four bolt. Pointless I know, but so far it holds true. If an engine with suffix code XYZ is a 4 bolt, so far any other engine that is the same suffix code is also.
    Suffix code located on the flat pad of the block behind the alternator, just forward of where the head meets the block.
