87 tbi rocker arm/valve adjustment
Discussion in 'The Garage' started by camokrawler, Apr 12, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    when i put my pushrods back in and go to tighten the rocker arm nuts down what is the best procedure to do so. i have heard a couple ways but don't know whats right:(
  2. dyeager535
    26,979
    TDC on each cylinder, tighten nut while spinning pushrod, when you feel the slightest bit of drag on the pushrod, stop, and then 1/2 turn more.
    You can do more than one cylinder at a time, and it really doesn't have to be at TDC for the cylinder, (just need to be on the base circle of that cam lobe)but one at a time just makes it easier.
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    zero lash plus one full turn of the nut is stock factory
    when a lifter is all the way donw in its bore then that is when to adjust it
