87 tbi running rich
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4k20, Apr 16, 2006.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i have an 87 v30 with a 454 its running rich when you first start it even when warm it does it i replaced the 02 sensor and cts but it still does it .. no ses light :confused:
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look really close at the injector spray pattern. Very likely that you'll see an occasional drip... :( Pretty common on older TBI's. Makes the exhaust dang near burn your eyes at idle.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I dont know how likely it would be but there is an internal regulator inside the tbi, its possible that its letting too much fuel pressure into the injectors. But more than likely as mentioned the injector themselves are leaky...happened to me on my 87 tbi 350.
  4. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    Big block TBI are prone to base gasket leaks. Another spot to check is vacuum line to MAP sensor. What I'm getting at too is vacuum leaks would be a number one cause of running rich. Have you checked fuel pressure? Have you checked for codes?
