87 TBI vapor canister
Discussion in 'The Garage' started by btolenti, Oct 16, 2005.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    For those with TBI, does your vapor canister connect directly to the TBI or is there an inline purge valve (vacuum or electronic)?
    Thanks!
  2. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Anyone? Someone's got to have an answer to this! :doah:
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I don't have a canister on my rig with tbi :dunno:
  4. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    yes, it connects directly to the TBI.
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    ....so is there a purge valve in between the tank and the canister then? :dunno:
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Nope, goes from the front of the throttle body directly to the canister.
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    yes, but what about the other line from the canister to the fuel tank?
  8. dyeager535
    26,980
    You might want to go look at the '85 or '86 TPI wiring diagrams over at thirdgen.org just to confirm, (that it's listed as EVAP purge) but on the wiring manual I linked to in your other thread, I see no cannister purge pin on the ECM. I may have missed it, as that seems odd, but who knows.
    I know my '88 TPI has a cannister purge connector.
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yeah, I was thinking the same thing (that the ECM doesn't have a pin out for it). But I also found these vacuum purge valves too, and am wondering if they are on any TBI setups....
  10. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    No purge valve on any of the TBI trucks I have owned; The vacuum line goes directly from the canister to a ported vacuum port on the throttle body. Using ported vacuum is how they got around the purge valve.
    Fuel vent line goes directly from the tank to the canister. No valves or anything to my knowledge.
  11. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Phew! That's a relief. Thanks for the help. :waytogo:
