87 Top Removal - Wouldn't budge!
Discussion in 'The Garage' started by tallmanearl, Nov 5, 2006.
  1. tallmanearl
    tallmanearl Registered Member
    Nov 4, 2006
    9
    Sacramento
    Hey, this summer I tried removing the top off of my 87 Blazer. Pulled bolts from sides and along top (front), also found 2 nuts under the lip in the rear and pulled those. The damn thing wouldn't budge. I pushed as hard as I could up and nothing but truck movement. Had the whole rig bouncing around. What is going on? Anyone have any idea?
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Could be stuck, if the rubber is old.
    Still sounds like you're missing some bolts, though... you said found the ones in the back ... though I swear there are some Torx bolts or something in the back as well.
    -- A
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Just make sure you got ALL the bolts and the dome light connector then get in there, fold up the rear seat (makes it easier) And push up with your back as hard as you can until it starts to break free.
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Det-cord...
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Make sure you get all the bolts undone,then stand in the back cargo area and standup. With your back against the top it will pop off.
  6. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    try to use a pry bar on the bed rail
  7. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Forklift....:crazy: I dont know but the rubber gasket was stuck on mine but did the method that everone is decribing and came right off.
  8. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Some WD-40 around the edges may help to soften the seal up. If it's stuck that bad, you might want to find some new weather sealing for it so it doesn't leak.
  9. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I took the top off my 1987 for the first time in its history and it was hard and HEAVY!All the bolts except the two at rear under rail can be seen from the back area. Be sure to remove the cover plate behind driver side and unplug dome light connector.
    If it has slider windows open them and get two people to push up there and one in rear window area. We did that and got the thing lose. The prior owner of yours may of put silicone on the rubber to keep leaks out if they did $$$$ order new seals.
    *There are no Torx bolts on a factory 1987 top!
  10. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    there are 4 bolts in the rear. 2 are attached to the guide pins and 2 to the top. I had to break it free with the pty bar. Did mine 3 weeks ago.
  11. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Ed-
    You finally broke down and took it off? Mine was the insperation, right?
  12. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    So you are saying you had to un bolt the guide pins?
  13. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Shouldn't have to unbolt the guide pins. I didn't.
    I did the back - stand up method and it worked.
    Maybe try the front & then the back. If it's still bolted down somewhere you should be able to tell.
  14. tallmanearl
    Nov 4, 2006
    9
    Sacramento
    Anyone know the best place to get good seals? Any tricks to re-sealing success?
  15. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    in the owners manual it tells you an order to go by for the bolts, but i never did it to get resealed properly. i just did the header bolts first to get it snug then the bed bolts. then tighten everything down
  16. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    lay on your back, and shove it off with your feet. really easy
