87 valve spring info
Discussion in 'The Garage' started by TBair, Apr 16, 2006.
  1. TBair
    TBair Registered Member
    Dec 14, 2005
    12
    Grand Ledge, Michigan
    im looking for info on the valve springs in my 350, diameter, maximum safe lift, rates anything. its a 2003 or 2004 goodrich stock replacement engine for 1987 TBI blazers.
  2. dyeager535
    26,979
    Try and do a search for the cam specs on here for a stock motor. Not sure that I've ever seen them posted (they are out there for the Vortec springs) but that would at least give you an indication of what the springs were dealing with stock.
    As cheap as standard springs are though, if there is a question as to whether they will work, I'd just buy a set of whatever the cam company says you need for them.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Read the info that comes with your new cam. Most state that there is NO warranty if you don't install the correct springs that the cam maker recommends.
